ArcGIS Web Editor: why another product?
5016
15
06-28-2024 02:01 AM
MappyIan
I like the look of the new ArcGIS Web Editor that was released this week for ArcGIS Online.  But it does raise the question of why add this functionality to another new application rather than simply extend the editing functionality that already exists in Map Viewer.  I'm baffled by the continual development of new products that perform subtly different tasks from existing products (Quick Capture, Field Maps, and Survey 123; Experience Builder and Dashboards).  Surely a better approach would be to consolidate and enhance the functionality in a single application?  In the case of Web Editor, it does seem like this functionality could have been integrated in to Map Viewer.
Just my thoughts.
RichardHowe
I totally take the point. I'm guessing there was some dev reason they couldn't incorporate it, but if that's the case just launch a newer version of map viewer.
I do however consider this an improvement on experience builder though. I accept you can perform a lot of the editing in there via a widget, but I don't need the hassle of making/maintaining a new EXB item for every map, just to be able to do slightly more than basic edits. At least this way I have a way of opening existing items with an app to do it
MappyIan
Thanks for the comments @RichardHowe.  Regarding Experience Builder, I wasn't meaning that the editing tools in EB should be enhanced in line with the new Web Editor, I was merely making the comment that EB and Dashboards offer a lot of overlapping functionality (much like Quick Capture, Field Maps and Survey123 also do).  The proliferation of multiple products that have a lot of similar functionality doesn't seem like an efficient use of resources when the time could be spent enhancing a single product instead.
RichardHowe
Haha, I don;t disagree 🙂
LarryYoung
Hi All,
First off, much time and thought went into whether to augment existing applications or create a new application.  In the end we decided a separate application was best and i'll give you two main reasons:
  1. Creating a focused app - by creating an application just for editing it gives us the ability to streamline workflows for that purpose.  If you create a single app to do everything, then you have to genericize some process as a result.  An example would be the toolbars across the top of Web Editor which are context based knowing the user is editing.
  2. Configuration - In a future release we will support configuration of  Web Editor to further support streamlining workflows.  For instance, you could configure Web Editor to support only updating attributes and save that as an instance of the application.  If the editing capabilities are rolled into Map Viewer, then the options for configuration are reduced if not eliminated.
Hope that helps.  Also worth noting much of the functionality of Web Editor will make its way into web components that will be available in Experience Builder and Map Viewer at the discretion of those teams (i.e., does it make sense for the application and its purpose) and in the context of those applications.
ClayDonaldsonSWCA
Thanks Larry - this makes sense and I am loving the new editor.
My main issue is that map viewer allows mobile workers to editor their data, but for some reason it was decided they cany use Web-Editor. Considering my organization has about 1000 mobile workers who use map viewer or experiences to review and edit their data. It seems like this is an unnecessary restriction to sell more creator accounts, rather than improving user experience.
I am hoping that restriction is lifted, otherwise very few individuals in my organization will actually use this great application.
RichardHowe
@ClayDonaldsonSWCA  I could not agree more. Please consider supporting the suggestion I have put forward here, and adding your own rationale for wanting this in the comments, to support the idea:
ArcGIS Ideas - Make web editor available to mobile workers
andreoudi
I would greatly appreciate it if the Editor widget in Experience Builder could be enhanced to offer more advanced functionality. One key feature that my company currently relies on is the copy/paste capability available in the Smart Editor widget in Web AppBuilder. This functionality is crucial in several of our workflows but is currently missing in both Experience Builder and  Web Editor. As Web AppBuilder is set to be retired by the end of the year, we currently have no viable alternative or backup plan to maintain this part of our operations.
What is your plan regarding this functionality? Will the Editor widget in Experience Builder be updated to include copy/paste capabilities? We are not interested in switching to another editor application such as Web Editor, as our current users in Web AppBuilder do much more than just edit data — they also rely heavily on features like filtering, running queries, and more. It’s important for us to maintain an integrated workflow within a single application.
LarryYoung
Hi andreoudi,
Can you outline in detail what your workflow is for copy/paste?  At this point, copy/paste is available in Web Editor, but as you mention, you have other aspects of your workflow that require capabilities outside of editing.
This is part of our dilemma with copy/paste.  The examples we have seen from organizations wanting to do copy/paste include bringing in temporary layers (like census blocks), copying from them, pasting the results into one or more polygons in a different layer, maybe updating attributes, and then running some further analysis.  With a workflow such as this, could easily argue copy/paste is not really an editing workflow and as such should be handled outside of the Editor widget/component.
Either way, important for us to understand exactly what you are trying to accomplish.
Thanks, larry
andreoudi
Hi LarryYoung,
Our process is quite similar to what you described. I work as a GIS engineer at a municipality, where our users often bring in temporary data—typically from geotechnical investigations conducted by consultants. These are usually delivered as shapefiles, containing both the geographic extent of the investigation (polygons) and the boreholes (points).
Using the copy/paste functionality in Smart Editor, the users update our geotechnical investigation layers (points and polygons – geodatabase layers). Once the data is added to our geodatabase, they enter the required information and attach any associated documents related to the investigation.
To me, this is clearly an editing process. Currently, this is the only method we have for updating our geodatabase layers. The users themselves don’t have GIS expertise—they are specialists in their respective fields. The same process is used across all types of investigations - environmental, noise, archeological and others.
