Make web editor available to Mobile Workers
18200
60
07-01-2024 11:53 PM
Status: Open
RichardHowe
I can't see the rationale behind making the web editor only available to Creators and higher. Anyone with a Creator licence already has access to ArcGIS Pro where they can edit their data with the full suite of desktop tools. The real beneficiaries of Web Editor will be Mobile Workers who have been out in the field and are potentially limited by Field Maps editing tools, and wish to tidy up their data when they are back in the office.
The Creator licence type is there for those who wish to create actual content i.e. hosted feature layers, webmaps, dashboards etc. not for those who simply wish to edit existing data.
Please reconsider the restrictive licencing of what, on the the face of it, seems like a really useful addition!
60 Comments
LarryYoung
Hi All,
Happy Holidays.
Thanks again for the comments.  I still have one questions that i'm not sure has been answered yet.  The main use case on this thread has been around mobile workers collecting data in the field and then coming back into the office and needing an easy to use web application for cleanup.
If that is the primary workflow, then can someone tell me what is missing from Map Viewer from an editing standpoint for that simple cleanup?  Yes, Web Editor may do it better/easier because it is a focused editing application, but it is designed to accomplish many advanced editing workflows as well.  This is the main reason for the higher user type requirement.
The answer for a simple web editing application for data cleanup by a Mobile Worker user type would appear to be Map Viewer, particular with the newer capabilities recently added such as batch attribute update.  Other capabilities still to come include split and merge.
So what editing functionality is missing from Map Viewer (Experience Builder is also an option, but i understand that requires configuring the app, etc.) for simple data cleanup of field collected data?
Thanks, larry
ClayDonaldsonSWCA
Hi Larry - Here is what I see as missing:
- Split and Merge
- Copy/Paste
- Selection management (add to selection, remove from selection, select by attribute)
I would argue that all of the functionality in web-editor is valuable to mobile workers even if it's allegedly an "advanced" workflow. I don't think it's very clear what ESRI considers advanced, or why all users shouldn't have access to such tools.
mthompson
I think you said it yourself. This is supposed to be a better/easier way to allow focused editing... so it should be available to those who would need an easier and better focused editing tool, which would be editors without access to Pro such as Mobile Workers and especially Contributors since the whole point of that license level is to edit in the office. If this is only for use by those who already have access to Pro, I guess I don't understand what the point of it is.
BlakeMorrison
@LarryYoung, I assume you're gonna get piled on at this point.
Map Viewer is clearly a much more advanced tool for, as stated by Esri, "Create, explore, and share interactive maps and geographic data with ArcGIS Map Viewer." Web editor is for "ArcGIS Web Editor is a data editing application in ArcGIS Online that streamlines data maintenance workflows. Web Editor provides a straightforward approach to editing for GIS and non-GIS users."
Esri made a product, told us what the product is for, then restricted use by the usertypes they've implied the product is for. Why is Map Viewer available to mobile workers? I would never send a non-GIS user into that.
@ClayDonaldsonSWCA
Split/Merge and all those selection options are now available in Experience Builder. Copy/Paste still to come I believe.
BlakeMorrison
@LarryYoung
"ArcGIS Web Editor is a data editing application in ArcGIS Online that streamlines data maintenance workflows. Web Editor provides a straightforward approach to editing for GIS and non-GIS users. The wide array of editing tools can be used for complex editing workflows."
Web Editor is still promoted for use by non-GIS users. Web Editor is still not avialable without a creator/professional licence.
Map Viewer is still available to non-GIS users and it is a much more powerful tool.
I appreciate you may have missed my last message, but the new update has got me back here wondering what on earth is the thought process here? I have users, editors, that need to perform edits in an editor. As it is, I do it in Pro rather than setup Experience Builder apps per task. It's not appropriate in anyway for a mobile worker to have access to map viewer capabilities - they are editors, they ned an editor.
Like, even just a subset of the web editor features in a web editor like interface that I could let Mobile Workers use - rather than build custom apps every time. That's what I thought the Instant App template was at first - but no.
LarryYoung
Hi Richard,
Please refer to this thread on the same topic: Make web editor available to mobile workers
While Web Editor is a strong application for simple editing, it also has many advanced editing capabilities with more to come.
Appreciate your feedback.  We will continue to evaluate the licensing of our products as feedback comes in.
larry
RichardHowe
@LarryYoung - I'm a little confused...did you mean to post that on another thread? It's just a link back here
LarryYoung
Sorry, @RichardHowe, got my threads crossed.
There have been other threads on the subject, so was just trying to keep the discussion in one place.
For better or worse, i don't have anything more to add to the subject that hasn't already been said in this thread.  We do appreciate and hear your feedback.
thanks, larry
LWWCGIS
I agree with many of the comments here as this seems very anti-consumer. I assume Contributor can't access Web Editor either... I typically buy Mobile Workers to give the most capabilities I can to our users. It doesn't necessarily mean they all work in the field. I will not be buying everyone a Creator license. I would suggest if Web Editor is for advanced users only, it should be removed it from instant apps and marketed as such with an explanation of why an advanced user would use it over ArcGIS Pro. OR the easier solution would just be to make Web Editor accessible to Mobile Worker accounts.
rmcooper_wcpss
I guess I'll throw in my two cents. I work under an Educational License. The User Type composition for that program recently changed dramatically and we now basically only have Mobile Worker User Types to cover users outside our core GIS team. The change was a bit of a rug pull, but that's for a different thread. Initially, all seemed well for us. Even though the idea of a Mobile Worker is nonsense for our organization - we serve desk workers almost exclusively -  the actual capabilities appeared to cover what those with that User Type need to do: View data in applications and create/edit data. Turns out, the truth is more nuanced...
When I look at the included licenses for Mobile Worker, Instant Apps are listed:
There is no indication here that only some Instant Apps are available to Mobile Worker users.
And when I go to deploy an Instant App, Web Editor is included as an Instant App:
It seems like my Mobile Worker users should be able to use Web Editor because it is an Instant App. There is no explicit indication in this interface suggesting otherwise. Imagine my surprise when I go to demo a Web Editor app with a Mobile Worker and they can't access it. If Web Editor is an Instant App and Mobile Workers have access to Instant Apps, then why don't they have access to the Web Editor?
I have since learned that the app description has the fine print specifying it is limited to Creator or greater in the App description in the Instant Apps gallery. There is also licensing info on the Web Editor's Requirements page. The function of the Web Editor is pretty obvious so it didn't seem useful to look at the App description. It just hasn't been my experience yet that Instant Apps might have additional license. From looking through all the other Instant App's App descriptions in the Instant Apps gallery, Web Editor is the only Instant App that requires an elevated license for usage. As such, it didn't occur to me that I'd need to look into the license requirements for an Instant App.
I guess my point is, if Web Editor is an Instant App and Instant Apps are a part of the Mobile Worker license, then Mobile Workers should have access to the Web Editor. If it's not covered by the Instant Apps license, then remove it from Instant Apps and return it to a standalone application.
Side note, I think many of us are well aware of the editing capabilities in the Map Viewer by now. The Map Viewer is wonderful, but it also serves a lot of functions:
  • Viewing data
  • Visualizing data
  • Configuring a map for an application
  • Analysis
  • Editing data
  • Editing form configuration
  • and more!
All those functions have buttons and interfaces that, for users who are not interested in or impressed by all the great things Map Viewer can do and only need to edit data, it's overkill.  The thing I admire about Instant Apps is how they each hone in on something that might be technically possible in the Map Viewer and then make that particular function more user-friendly.The beauty of the Web Editor is that it puts the focus on the editing. There are fewer interfaces to get lost in and distractions for users. Users can toggle layers on and off but there's no changing symbology. The focus is on editing the data. It's a shame all users with editing capabilities can't access it.
Looking through this thread, it seems like the many compelling arguments made for
