When I add to the list of custom zoom setting in the App Builder, ESRI default basemap do not appear or render. What do I need to do in order to utilize ESRI basemap to my zoom levels?
Solved! Go to Solution.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Chet,
The LODs (levels of detail) have to match the LODs that the basemap is cached at. So if you are using a esri basemap you can Not set the LODs to values that are not in the map service tile info. For example:
Tile Info:
