Working with WebAppBuilder behind a corporative http proxy
19829
17
07-31-2014 05:54 AM
AlexisRodriguez
As some users before, our team was experiencing problems with WebAppBuilder and ArcGIS Portal login, once nodejs was already initiated and portal url was verified successfully. Our users credentials were never validated and we were unable to login (incorrect username or password message). We recently found out that it was due to some kind of compatibility issue with our corporative http proxy.
Does anyone know how to configure WebAppBuilder to work behind a corporative http proxy? Thanks!
TarigAhmed1
Hi Alexis, Everyone,
I'm having the same issue now with Web AppBuilder Beta 3,   Beta2 still work just fine !!!!10-14-2014  Proxy Erro on Beta 3.png
Any idea?
Thank you,
Tarig
YichiLiu1
Hi All,
I got the same error when I was using my organization's account to log in, but I was able to log in using a trial account. Any idea why?
Thanks!
VeronikaBraatz
Hi Everyone,
the same Problem occured today with Web AppBuilder 1.0. The solution is similar to Junshan's with one exception.
The steps that solved it for me were:
1. Open server/proxy.js
2. Change the line (Lines 45 and 62)
proxy: args.proxy? args.proxy: undefined,
to
proxy: args.proxy? args.proxy: 'http://proxy.our.Company:Port',
3. restart node server
I hope this is helpful
DonaldBaddon
Hi All,
I am facing similar problem as above , can one help me out. I am trying this in my office pc.
below is the code of  server/proxy.js
I am facing below error :
this how my proxy settings looks like in IE:
BledarBirbo1
Hi Donald.
Did you ever find a solution for this ?
I am getting the same error.
Thanks.
DiegoTrivino
Hi Donald and Bledar,
I have the same error, ¿Could you find a solution?
EricPfirman
I followed the solution above and added our corporate proxy to proxy.js
          proxy: 'http://ourproxy:8080',
The error I get is:
     Error: tunneling socket could not be established, statusCode=407
Status Code 407 = Proxy Authentication Required
How do I provide this authentication?
PuLin
START "Web AppBuilder for ArcGIS" /B %nodeFile% %serverjsFile% -proxy="http://username:password@proxyservername:80"
Edit start.bat using the string above.
