Widget screening no longer loads after layer services are set to private
1208
10-17-2024 10:53 PM
gilberto-matos
Hello!
I have an application generated with Web AppBuilder 2.2. All widgets have always worked perfectly, with a portal map, where the services of the layers added to it are not private. What happens is that now the company's managers have decided to make the services that the map uses private. The screening widget simply does not load anymore, and I have tried several ways to find out the problem. It is asking for the portal/arcgis manager username and password. Even though I enter these usernames correctly, I cannot get the widget to load as before. Below is the error that the console displays, as well as a print of the line. Any help, I appreciate it.
@RobertScheitlin__GISP  i remember you helping me in other situations. Do you have any tips you could give me? Thanks!
Thank you!
Gilberto.
