When using the search widget for locating address points my pop up box appears then quickly closes losing my zoom to ability. It use to stay up until the user closed the attribute box. Any ideas?
3308
6
04-27-2016 05:47 AM
ChetShuler
Attribute pop up box appears then quickly closes..
RobertScheitlin__GISP
Chet,
  What version of WAB are you using? Have you made any customizations to WAB core files? Are you using any custom widgets?
ChetShuler
I just did some more testing. It appears after using the summary widget for counts is when the issue occurs. Pops up quickly then closes. Even after I close out of the summary widget the issue still exists. Working fine otherwise.
No custom widgets. Everything straight out of the box. Version 10.3.
Chet,
  Is there any error in your browsers web console?
ChetShuler
I'm limited when it comes to coding. I opened the console and errors are present. Hopefully this helps.
/apps/webappviewer/jimu.js/main.js:1364 jimu.js init...
/apps/webappviewer/jimu.js/main.js:11 Load Config: 337.422ms
/apps/webappviewer/jimu.js/main.js:327 Load Map: 509.838ms
/apps/webappviewer/jimu.js/main.js:130 widget [widgets/Search/Widget] created.
/apps/webappviewer/jimu.js/main.js:130 widget [widgets/HomeButton/Widget] created.
/apps/webappviewer/jimu.js/main.js:130 widget [widgets/Scalebar/Widget] created.
/apps/webappviewer/jimu.js/main.js:130 widget [widgets/ZoomSlider/Widget] created.
/apps/webappviewer/jimu.js/main.js:130 widget [widgets/Coordinate/Widget] created.
/apps/webappviewer/jimu.js/main.js:130 widget [themes/LaunchpadTheme/widgets/Header/Widget] created.
/apps/webappviewer/jimu.js/main.js:130 widget [themes/LaunchpadTheme/widgets/AnchorBarController/Widget] created.
/apps/webappviewer/jimu.js/main.js:301 Load widgetOnScreen: 304.699ms
/apps/webappviewer/jimu.js/main.js:130 widget [widgets/Summary/Widget] created.
js.arcgis.com/3.16/init.js:182 Error: Invalid URL.
    at Error (native)
    at Object.g.load (http://js.arcgis.com/3.16/init.js:1042:343)
    at http://js.arcgis.com/3.16/init.js:181:69
    at c (http://js.arcgis.com/3.16/init.js:66:221)
    at d (http://js.arcgis.com/3.16/init.js:66:10)
    at resolve.callback (http://js.arcgis.com/3.16/init.js:67:350)
    at c (http://js.arcgis.com/3.16/init.js:66:436)
    at http://js.arcgis.com/3.16/init.js:185:300y @ js.arcgis.com/3.16/init.js:182
js.arcgis.com/3.16/init.js:182 Error: Invalid URL.(…)y @ js.arcgis.com/3.16/init.js:182
Chet,
  I am not sure why you are getting that error. I would try starting a new app an going through you configuration steps again and see if you still have this issue.
ChetShuler
Well I have another app that uses the summary widget doing the same thing. Its like the widget is closing or disabling the attribute pop up to display the summary counts. I use the summary widget one time the pop up is dead no matter if I close the widget or not. True for both apps.. I believe there's something in the summary widget code causing the problem, but I'm not a programmer.
Appreciate your help..
