When labels are turned on in web map, it "breaks" the app
4560
07-30-2015 08:01 AM
RobertSommers
Is anybody else having this issues? Any solutions?
Basically, when I create a web map with labels and use that as my source map for an app, it "breaks" the app (doesn't load, can't see data, etc..).  When I turn off the labels in the same web map and use it as my source map it works fine.  I'm seeing the same problem regardless of which web map it is.  I've tried changing label styles, values, etc...
RobertScheitlin__GISP
Derrick,
   This seems to be a known bug and will be fixed in the 1.2 release of WAB dev, which is schedules for release in early August.
AGOL update has broken custom apps built with WAB 1.1
Derrick,
RobertSommers
Thanks, Robert.  Would that explain why older apps (from a year ago) still label and work fine?  Looking forward to that update, ESRI....
XiaodongWang
The older apps sill work fine because of the webmap of that app  is hosted on Portal, not hosted on AGOL,  AGOL has updated js-api to 3.14, but Portal10.3.1 use 3.13 yet.
RyanGatchell2
I seriously thought I was going crazy...  Thanks for posting!
