What happened to Smart Editor?
2981
06-02-2021 01:51 PM
CRHII-NNS
Our team is currently trying to build an application and utilized the smart editor widget, but it appears to be missing.
Is this widget still supported as an out of the box option in webapp builder?SmartEditor.PNG
Tags (3)
jcarlson
It is still supported. Can you confirm that it's not already added someplace else in the app, maybe the header bar or a side panel? You can only add a single Smart Editor widget in your app.
- Josh Carlson
Kendall County GIS
JoseSanchez
Hello Cody,
We are using SmartEditor is our 10.6 and 10.8 Portals and they work fine.
The only issue in 10.8 Smart editor is missing the option "Preset", it is disabled.
Thanks
AlixVezina
Hi @JoseSanchez ,
Presets are disabled from the Layer Settings and should now be setup from the section in the Attribute Actions tab.
CRHII-NNS
It was in the header bar. Will be deleting this question.
jcarlson
It's still a valid question, and a future user may run across the same issue. I'd leave it up as a reference.
- Josh Carlson
Kendall County GIS
