Webapp Viewer - How can I change the base map?
1037
05-21-2018 10:30 AM
WarleyMendes
Hi Guys,
Every time I access the Webapp Viewer to build or test my widget it show the USA dark gray Map Base.
https://localhost:3344/webappviewer/?config=sample-configs/config-demo.json
The problem is this map uses wkid 102100 and I always need to convert to wkid 31984, wich my maps uses.
I'd like to know if is it possible to change the base map to a specific map published on my Server Manager?
This way, I will start the Webapp Viewer with my city base map.
Warley
RobertScheitlin__GISP
Warley,
   The basemap can be set to your orgs designated base map by setting the the default basemap in your orgs AGOL.
How To: Configure a default basemap in ArcGIS Online
