WebApp Builder-Developers Edition without using AGO maps
4221
01-08-2015 10:14 AM
EricVenden
Is there a way to get the WebApp Builder-Developers Edition to work with internal map services and not those published through ArcGIS Online?
Or will the workflow for creating apps include the necessity to tie the app to a webmap published in ArcGIS Online?
RobertScheitlin__GISP
Eric,
   See this thread for a new work around widget
LocalLayerWidget and AccessifizrWidget
Eric,
AnthonyGiles
Honored Contributor
Unfortunately your basemap still needs to be served via AGOL or Portal
EricVenden
Thank you Robert & Anthony,
I will look at the LocalLayerWidget.  Hopefully the basemap requirement will change in the future.  Although I like AGOL for certain uses/application, I would also like the freedom to NOT use it.
