WebApp Builder Dev 403 Forbidden
2849
6
08-10-2020 02:06 PM
BrianKeller__GISP
So i've got a doosie!
I have a WAB app im trying to deploy on my web server via IIS.
https://edacarc.unm.edu/test/
We have even deployed a simpler default app, with zero modifications made, still the same issues:
https://edacarc.unm.edu/test6/
I have been getting a revolving door of errors, which seem inconsistent, and in some cases/networks, no errors at all...
  • 403 Forbidden on widgets/.js files
  • CORS errors
  • invalid MIME types
ESRI support has confirmed the app file runs without issue on their local machines, so the assumption is that its something with how our IIS/Server is configured.
Help!
Tags (3)
RobertScheitlin__GISP
Brain,
   The only error I am seeing on those to test site links is an svg mime type issue. Seems like your web server does not have the svg mime type configured.
BrianKeller__GISP
Hi Robert,
Thanks for the quick reply! I was hoping you would chime in, and fortunately (or not) you seem to be one of the lucky folks who isn't encountering the 403/CORS issues. We had a couple of font MIME issues, and the SVG was on my list to fix as well. We also saw the following, more troubling MIME warning in some cases:
The biggest frustration with all of this seems to be the inconsistency.
Brain,
   That sounds like your json mime type is not configured properly. the json mime type should be configured as "application/json"
BrianKeller__GISP
Here is whats currently setup.
Brain,
  That does not make sense based on the warning message you posted above. And Like you said earlier even stranger yet is I don't get that arning youing your link provided.
BrianKeller__GISP
Yea, we've gone through 3 esri support reps and tried a variety of possible solutions all with no luck.
If you have another network to try on, give it a shot, it seems to vary person to person.
Looking at standing up an entirely new VM and seeing if anything changes.
