Web AppBuilder Smart Editor select feature to copy didn't work
16318
13
06-10-2020 01:43 AM
Barış_SerkanAKIN1
i create a  app with Web AppBuilder.  When i try to add fateture to layer with "Smart Editor\Select features to copy\Crea...
How can i fix this error? There is another method to add feature to layer on Wep App?
I attached screen shots, may be can help.
Good works.
Tags (1)
Andy_Morgan
I also experienced this error in the developer console after updating my web map, but then it went back to working normally again after I updated my SmartEditor widget settings. Might have been something related to which layers and fields were editable, I'm not totally sure.
AlixVezina
Hi Barış Serkan AKIN
Thank you for sharing this with the community.
We have taken note of this issue and it will be resolved with the upcoming software update.
Regards,
Alix
AlixVezina
This should now be working properly, please let us know if you are still experiencing issues.
GoulburnBroken
Hello Alix Vezina
We experience this same issue within our ArcGIS Enterprise 10.7.1 Portal environment.
Should it be working in 10.7.1 Portal?
I assume your fix was applied to ArcGIS Online?
Thanks.
Great detailed question by Barış Serkan AKIN
Barış_SerkanAKIN1
We encountered issue at Enterprise Portal 10.8 and still exists.
There is a patch for this issue?
AlixVezina
This was only fixed in ArcGIS Online and will only be available in a future update of Enterprise.
GoulburnBroken
Thanks for the update Alix.
ShelleySchulte1
Alix,
Is there any news on this to be implemented to enterprise?  Thanks
Shelley
AlixVezina
I'm sorry, this fix should be made available in Enterprise 10.9, but won't be available in previous versions of Enterprise. If you need this fix earlier, you can try adding the current version of the Smart Editor widget as a custom widget to your Portal: Add custom widgets—Portal for ArcGIS | Documentation for ArcGIS Enterprise
