Web AppBuilder not respecting removed service layers in saved AGOL map layers
7445
13
05-01-2015 08:19 AM
Mark_
Hello everyone.  I have several AGOL map layers that were created by paring down larger map services.  When I point Web AppBuilder to a web map containing one of these map layers, the created web app displays all of the layers in the source map service rather than reduced number of layers of the AGOL map layer.  I hope that makes sense.  Am I missing something or is this a shortcoming/designed behavior of Web AppBuilder?  Please note, I am not using the developer version.  Thanks for the help!
Mark_
For anyone interested,  I recently followed up with ESRI support on this and was glad to hear that release 3.9 will address this issue.  This is not the release scheduled for next month (July 2015) but the one following sometime in the fall.
JeffWard
Honored Contributor
Are they pared down using a query?
Jeff Ward
Summit County, Utah
Mark_
Jeff, they are not.  I'll elaborate a bit more.  I have a map service with layers A through Z.  From an AGOL webmap, I remove all the layers except for B, D and F.  I then save this BDF layer to AGOL My Content.  While AGOL webmaps display only layers B,D and F, the Web AppBuilder app displays layers A-Z of the source map service.
TomSellsted
Mark,
Have you tried flushing your browser cache?
Regards,
Tom
Mark_
Tom, I have tried clearing the cache.  That did not do the trick.
TomSellsted
Mark,
Any chance that you are using a widget that displays your services directly and not from your web map?
Regards,
Tom
Mark_
That certainly appears to be the case.  Hopefully someone who knows the inner workings of the widgets and app can tell us definitively.  My hope was that the deep integration between Web AppBuilder and AGOL would allow this type of layer configuration to carry over just as popup configurations do.
TomSellsted
Mark,
Is the application published so we can view it and maybe figure out what is going on?  or URL for rest service or web map?
Regards,
Tom
JeffWard
Honored Contributor
Have you tried creating a new map, adding the layer you created from the other map and creating the app from the new map?
Jeff Ward
Summit County, Utah
Mark_
I've also tried that, yes.
