Web AppBuilder Kicks me out to AGO Login Screen
1887
07-06-2017 11:45 AM
JustinNettleton1
When I go into my AGO and click on a web appbuilder application and try to edit it, it starts loading the app to edit then kicks me back out to the AGO log in screen. So I can get into the back end of the app to edit it.
Anyone else having this issue?
RobertScheitlin__GISP
Justin,
   So it's in a constant loop?
JustinNettleton1
Yes, I log in and go to the app in AGO and click on "Edit Application" and it starts to load but then goes right back to the login screen. Login in again and does the same thing.
I am thinking maybe app is corrupt?
Are you using http or https protocol?
JustinNettleton1
We are using HTTPS.
OK,
   I had seen where this was an issue for someone when using http but since you are using https already then this will require a call to tech support.
