Web AppBuilder Edit widget required fields
2728
06-14-2016 01:02 AM
AveKargaja
I wonder if it is possible to mark an attribute field in Web AppBuilder Edit widget (dev edition, version 2.0.1) as "required", as it was possible to do in the flex apps? (in flex xml <field name="field" alias="Field" required="true"/>) The minimum is just to add an asterisk next to the "required" field, but there would be no control whether it is being filled with data or not.
My feature layers are usually added to my webapps through the LocalLayer widget.
