Problem with Web Appbuilder Timeslider widget configuration limitations
2030
06-13-2016 11:02 PM
RichardMacNeill1
I have designed a time enabled ArcGIS workspace. I have been able to configure the time slider to adapt it to the data, the information provided, the time increment and the country I am working in (Australia). However, when sharing this as a service and publishing as an app, the time slider widget provides no apparent means of duplicating these modifications and insists on using two pointers for start and end dates. Does ESRI have plans to update this widget to be consistent with the design flexibility in ArcGIS and within the JavaScript API?
Tags (1)
