Web AppBuilder: Edit Widget Issue with Required Field from feature service
2790
07-19-2021 05:02 PM
AlexP_
Hello,
I am the admin. I have AGOL web AppBuilder. I published feature server from an ArcGIS server then added item to AGOL to store credtinals. . I already have a required field. I tried to use edit widget but I don't see it in edit to create. but I CAN EDIT existing data. Please kindly assist as soon as possible. Is it something glitch that is not accept required field in edit widget to create a new point?
AlexP_
Hello,
Thank you for sharing. I learnt that I hadn't enable point Z editable as this is the first time with Z. It is working now.
KeithGerhartz1
Did you specify Create as one of the allowed operations on your feature service?
[cid:[email protected]]
AlexP_
Yes, I added screenshot.  it is allowed create.
DrVSSKiran
Make sure your feature service is the editable mode. And you need to do only few settings in your edit widget tools refer below figure.
1. If not enable in editing mode go the feature layer setting and enable it following options refer screenshot.
2. apply the following setting in edit widget tool
once you have done the following settings,  you click on the edit widget,  and you will see the editable option.
Here is the webapp link: https://vssk.maps.arcgis.com/apps/webappviewer/index.html?id=d88d7b859878463d8c9ddd0b38f257d6
AlexP_
Hello,
