Web App Builder 7.4\2.15: How to remove layers added to the App?
1633
03-16-2020 02:09 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out to remove layers added to the App.
Jamal Numan
Egge-Jan_Pollé
Hi Jamal NUMAN,
A layer is not added to an app. A layer is added to a map, and this map is added to app.
So, if you want to remove a layer that is visible in an app, you will have to remove it from the map.
Two options:
  1. Edit your map in ArcGIS Online (or your Portal)
  2. Edit your map directly from within the Web AppBuilder for ArcGIS:
    • On the Map tab, choose Edit this map
    • A separate window will open, where you can actually edit the map directly - see the 2 screen captures below
HTH,
Egge-Jan
Egge-Jan_Pollé
Hi Jamal NUMAN,
Two options:
HTH,
Egge-Jan
JamalNUMAN
Many thanks Egge-Jan Pollé for the help. It works with me
Jamal Numan
