WAB Print Widget
779
01-21-2019 11:40 PM
MiraEl_Koussa
Greetings to all,
I have a WAB with the print widget. however, when i try to print the labels that are displayed are read from the DB instead of the layers name.
how can i change the display of the labels so they can read from the layers available in the web map?
thank you
Mira
AlexP_
Have you tried to change the label rename from the web map? If it is still not working, maybe should try rename the label from the DB and republish it.
