WAB Attribute Table configuration not saving
1309
08-17-2021 11:34 AM
Kara_Lara
Having an issue w/ Attribute Table (v. 2.9) configurations not saving. I'm using WAB Dev Ed 2.12 to configure which layers I want displayed in the Att Table & which fields of info I want presented to the user. I make all my changes, save the Web App, & download, but in the resulting App, layers are being displayed that I have turned off & layers I had turned on, aren't displayed. When I enter the Att Table configuration again through WAB, the same incorrect configuration appears.
Furthermore, it appears layers are also listed out of order.
Kara_Lara
Someone replied: "I will join maybe to your question and ask is there a limitation of how many columns can be displayed in Attribute Table? And also in pop-up configuration, is there a limitation for number of attributes to be displayed?"
This was, in fact, the case. When I removed some layers from the end of the list while configuring the Attribute Table in WAB, then proceeded to turn layers I wanted on that were higher up on the list, my changes saved without issues.
Thank you for your contribution!
