Upload Shapefile to WAB
4489
08-18-2015 06:36 AM
DiegoLlamas
Hi, good morning. Does anyone knows if there is any custom widget that let the users upload a Shapefile to WAB? Thank you for your help!
Diego
RobertScheitlin__GISP
Diego,
   I have helped another user convert the JS API add shapefile sample to a widget here:
Re: How to use JS API Samples to Make WAB Widget?
Diego,
DiegoLlamas
Hi Robert good morning,
I download and use the add shp file widget and works great. I just want to know if there is an other version of this widget, one that has the option to clear results. I play around modifying some parts of json files but I am not an expert and adding the clear result goes way beyond my expertise.
Thanks for your help!
Diego
Diego,
   No it was more of a tutorial on how to take a JS API sample and make it a widget. I will eventually migrate my Flex Shapefile widget over to WAB but don't know when I will have time for that yet,
