Trying to have attribute widget honor the time slider widget
2960
03-11-2016 08:56 AM
PatKeegan
I have a time enabled WAB map using time slider widget. We also want to use attribute table widget but it is not recognizing time slider parameters.
So the records in the attribute table do not display what is shown on the map....and I'm all like 'whats up with that?'
Ideally, the map and table should show same records.
demo here if interested: https://maps.wheaton.il.us/mapviewer/attr_test/
Any advice on how to get these working together appreciated
PatKeegan
I was informed that this is the functionality as designed. the two widgets access information independently.
PatKeegan
christinehall
can you explain me, how I get the date format at the time slider in your example?
In my app looks like this: 31.12.1935 01:00 bis 31.12.1940 01:00
and I would like to get: 22.12.15 bis 27.04.16 without time.
Many thanks in advance!
