the added layers will get reset after a success query
1335
06-19-2017 12:39 AM
simoxu
by MVP Alum
The visibility of my added layers (one service with multiple layers) will be reset after the query result is added to the layer list.
Please let me explain it a little bit:
1) I added the "infrastructure Water" map service using Add Data Widget:
2) I change the visibility of the layers under "Infrastructure Water"
3) I performed a query in the Query Widget, the result will be added to the top of the Layer List, this is fine, but look at the "Infrastructure Water" layers, the visibility of them are reset to the initial status!
Have you come across the same issue, or I am the only unlucky one
Any advice or suggestions are highly appreciated!
Thanks.
simoxu
by MVP Alum
Derek Law
Hi Derek,
Have you or any of your customers come across this issue?
When you use Query widget, Add Data widget and Layer List Widget together, it seems there is a problem.
Thanks.
DerekLaw
Esri Esteemed Contributor
Hi Simo,
No, I have not heard of this issue before. Please contact Esri Tech Support and open a case. Please establish a repro workflow so they can investigate further.
Hope this helps,
simoxu
by MVP Alum
Hi Derek,
Thanks for your reply. I'll contact the Tech Support.
