Select - stuck click handler: bug or feature?
392
08-29-2019 12:55 PM
by Anonymous User
Not applicable
If I use Lasso in Select widget in WAB 2.12 DE it stays stuck 'on'. I can see this confusing users. It contradicts what the tooltip itself says! It only deactivates if you again click the green Select button. I'd recommend it deactivate after a single lasso outline, if that is by design. Or hopefully it is just a bug and will be fixed.
