Select Record on Attribute Table clicking on the Map
988
11-29-2016 08:33 AM
NatashaManzuiga
Hi all,  in my web app if I I click on a record in the attribute table it select the linked record geometry on the map.
If I click on a map, nothing happens on the attribute table widget...
Is it possible when I click on the map to select the linked record on attribute table widget?
Naty
RobertScheitlin__GISP
Naty,
  To do that you would have to use the selection widget. There is nothing setup in WAB for you to just be able to click on the map and it select the row in the AT widget. You can also click the popup menu for a feature and chose open in AT widget.
