Route widgets in Webapp builder: Plan route/direction
3198
06-12-2019 05:47 AM
SofiJohansson
Im trying to add a direction or/and route widget to a webapp. But when trying to configure the widget (in the below image the direction widget), the default Route URL does not work. Any tips on why?
I have an organisational account so a lack thereof is not the problem.
Thanks!
Sofi
RobertScheitlin__GISP
Egge-Jan_Pollé
Hi Sofi Johansson,
Same for me: url works fine and I was able to calculate a route (see screen capture below).
Did you find the reason of your error already?
Cheers,
Egge-Jan
SofiJohansson
Yes now it suddenly works! It hasn't since about 10 this morning. Needed a good luck charm I suppose
Thank you for your replies!!
Groetjes mvh
Sofi
