Re: How do I edit pop-up size and location?
3886
04-24-2015 09:52 AM
JeffHyder
Ok guys and gals, I am relatively new to all of this but I need to learn how I can do this in the Web AppBuilder. I am trying to display a parcel highlighted and be able to print it but the huge pop-up is smack down in the middle of the parcel which is highlighted. When I close the pop-up my parcel that was highlighted is no longer highlighted. I need either the pop-up to disappear after say 5 seconds leaving the parcel highlighted or for the pop-up to be to the top and left out of the parcel. Any and all help will be greatly appreciated.
RobertScheitlin__GISP
Jeff,
   Are you highlighting the parcel by just having popups defined for that layer and then clicking on the parcel or are you using some widget to select the parcel?
JeffHyder
I would like both, where you could simply click or use a search function by PIN number, owners name, or address.
