Query Widget - View Attribute Table - showing fields not visible
3048
8
11-02-2021 01:02 PM
LauraHeartwood
When I view the attribute table using the results from the query widget I end up with an attribute table that is showing fields I do not have visible under the table view settings for the web map the application is using. I have gotten around this by deleting some fields, although fields with the name "sensitive" will not delete, no matter how hard I try. The attribute table is also not reflecting the order of this table on the backend. Any tips would be much appreciated, thank you!
ABishop
You're welcome!
If you suspect a bug, you can find it here:  https://support.esri.com/en/Search-Results#search?q=web%20app%20builder&content-type=Bugs
If you can't find one and still suspect a bug, you can contact ESRI technical support and have them assist you.  They will log it as a bug if one is found.
Amanda Bishop, GISP
ABishop
Hello @LauraHeartwood
Try hiding the fields in the data source before publishing the service.  Also, you can modify the attribute table to hide fields in the web map and depending on the type of web mapping application you are using, there are options to configure the attribute table fields.
Amanda Bishop, GISP
LauraHeartwood
Hi Amanda,
Thank you for the quick reply. I have figured out a way to configure the default attribute table within the web app, but this attribute table is different than the attribute table you are directed to when you view the results from the query widget. I am wondering how to configure that one. Thank you!
Laura
ABishop
Try customizing the content in the query widget.  See attached pic.
Amanda Bishop, GISP
LauraHeartwood
Thank you Amanda. I did configure the content exactly how I wanted it and really thought it would fix my attribute table, but unfortunately it doesn't. I wonder if this is a bug.
ABishop
You're welcome!
Amanda Bishop, GISP
KristinaMarkocevic
any updates on the issue? @LauraHeartwood
HelenCooper
Hi Laura, I've also been trying to get this logged as a bug, but was (frustratingly) told to log it as a feature request.  But it really does seem like a bug to me!  Have you managed to log this?
Helen
LauraHeartwood
Hi Helen,
I have not tried to log it as a bug yet, interesting that they told you to log it as a feature request!
Laura
