Points will not render in Web App Builder if labels are added
2475
08-01-2025 12:54 PM
aaaker
In ArcGIS Enterprise I have a web map that is being displayed publicly with web app builder. I've added an address points layer (published to our AGO, and available publicly). The points draw fine until I add simple labels, then they no longer draw at all. They display fine in the webmap, but not at all in Web AppBuilder. This application has been around a long time and this just recently became a problem.
CodyPatterson
MVP Regular Contributor
Hey @aaaker
What version of Enterprise are you using?
Along with this, have you tested on other browsers to see if it may be a browser issue?
Cody
aaaker
We are on Enterprise 11.2. I have tried it on other browsers and it doesn't work on any of them.
KenBuja
MVP Esteemed Contributor
Have you checked whether the labels are showing correctly when opened in Map Viewer Classic? Map Viewer Classic and Web AppBuilder use ArcGIS Maps SDK for JavaScript 3.x while the new Map Viewer uses ArcGIS Maps SDK for JavaScript 4.x. If your labels use something only available in 4.x, Web AppBuilder won't be able to render them.
aaaker
They do show in Map Viewer Classic.
