Overwriting Layers
687
07-28-2020 01:38 PM
BennyNein
Hello All,
I am asking for some help with the overwrite feature in ArcMap. I have a Web Mapping Application in AGOL which pulls data from a created Web Map. In said Web Map I have uploaded feature layers from ArcMap.
My work flow is ArcMap --> AGOL Web Map --> AGOL Web Map Application.
The data that is in these feature layers changes frequently so what I do is update the data in ArcMap and then overwrite the published layers in my AGOL folder.
However, when I finish overwriting the layer and check my AGOL Web Map none of the data is updated? From what I can tell, I need to add the hosted feature layer to the web map again.
The only downside to that is the name & symbology are different and I need to then go back in my Web Map Application and relink everything.
Is there anyway I could make this a more streamlined process? I'd appreciate any feedback. Thanks.
