OK and Cancel buttons are not working for me, any suggestions?
8773
19
03-12-2015 03:42 PM
MichaelSouffront
When I go to the web app builder to create an app, I can't add widgets or do anything because the OK and Cancel buttons of any pop up window in the appbuilder don't work.
StanMcShinsky
Michael Souffront​,
Can you please give us more information to help you out better? What version are you working with? AGOL, Portal or Developer?
-Stan
MichaelSouffront
The AGOL version.
AlexanderNohe1
Honored Contributor
Try clearing your browser cache.
16 Ways to Clear Your Browser's Cache - wikiHow
Does this happen in all browsers or just a few?
StanMcShinsky
Michael Souffront
Everything seems to be working just fine on my end for the OK and Cancel buttons. Have you tried to clear your browser cache? This might be a browser problem. I am using Firefox and Chrome and no problems here.
-Stan
MichaelSouffront
It is now working, I didn't do anything today though.
I did clear my cache and restarted my computer last week and that didn't work then.
Anyway, thanks for your responses.
Michael
MathiasDOLIDON
Same issue as Michael.
WAB 1.0 Dev Edition freshly installed from Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers  (today)
The locale is French. Cache cleared. Server stopped/started after the first time the issue happened, just in case.
All starts fine until the welcome page. I hit "create" and fill in the fields. Neither OK nor Cancel do cause any action, apart of the whole dialog box getting surrounded by a blue rim. The dialog box can be closed with the cross icon in the top right corner. I observe the same behaviour in the "import" dialog box : OK and Cancel have no effect whatsoever.
NOTE : issue seems to be Chrome only.
Regards,
Matt
StanMcShinsky
Matt,
I don't have a solution for you I just want to clarify for other users.
  1. What version of chrome are you using?
  2. Does it work in Firefox or IE?
    • If so What versions are you using.
-Stan
HumzaAkhtar
exactly the same issue as Matt,
Chrome version : 41.0.2272.89 m
No issues in Firefox. So I have switched to Firefox. However I would like to know the reason behind it.
Firefox version:  36.0.1​
MathiasDOLIDON
Hello Stan.
Issue repeated this morning with Chrome 41.0.2272.89 m
No problem with IE 11.0.9600.17691 and Firefox 32.0.3
All running on Windows 7.
Regards.
