ListView Widget Help
6677
24
12-17-2019 03:08 PM
SamLee1
KenBuja
MVP Esteemed Contributor
The first error points to line 47
layer.queryFeatures(query, lang.hitch(this, function(featureSet) {
which means that "layer" is undefined. You get that earlier at line 39
var layer = this.map.getLayer(this.config.layerId);
Have you set the layerId property in the config to a valid layer in the map?
SamLee1
Hello Ken,
Thanks for the response.
What do you mean by that?  I went through all the steps.
Was that one of them?
KenBuja
What do the config.js file and the Settings.js file in the settings folder look like? Does they contain an entry for layerId? This is mentioned in the section "Customize the Settings page". This is how this.config gets variables assigned.
SamLee1
Settings.js:
I do not have a config.js in my settings folder. There wasn't a step for that in the tutorial.
KenBuja
Sorry, that should have been config.json.
Have you gone into the debugger in the Developer Tools and determined what value is being returned for this.config.layerId?
SamLee1
Yes I did use the debugger. There is no value returned as there is an error.
config.json file:
KenBuja
What does the debugger show for this.config?
SamLee1
I do not get what you are getting as there is no debugger in my Chrome tools.
KenBuja
In Chrome, it's under the Sources tab.
