The message you are trying to access is permanently deleted.
I thought I had posted this on here already, but I can't seem to find it....
I'm using the tab theme and I have the layer list opening by default in the side panel. Is there a way to have it open with all the layers already expanded showing the symbology without having to click on each individual layer?
George,
What do you mean
I cannot see where to add the code mentioned above.
What version of WAB are you using?
sorry i thought i was replying to the main thread, what I want is the mapservices which are grouped to expand once the map is opened without clicking each drop down arrow.
In the thread there was a code block to add to the layerlistview.js
George,
You are replying to the correct thread but I am not sure why you made the generic statement
Can you be more specific? What version of WAB are you using?
WAB 2.3, i want in the TOC all the map services to expand when opened. I assume i need to modify the layerlistview.js in the WAB/client/stemap/widgets/layerlist folder by adding some code. For some reason I was under impression 2.3 automatically had the option to expand the TOC.
George,
2.3 does have a LayerList menu option to expand all layers in the list but it is a menu option at runtime and not something that is configurable in the widgets settings dialog. If you want to expand the LayerList widget automatically then you have to add code to the LayerListView.js as this thread suggests.
For 2.3 you should look at this thread for the proper code changes:
https://community.esri.com/thread/189567-show-legend-in-layer-list-widget-by-default#comment-663376
Thanks Robert, where is the menu option at runtime? I am not understanding that. Will it help if I attach my layerlist widget.js?
George,
It is just to the right of the "Operational Layers" text in your LayerList widget (the icon with lines and a checkmark).
Oh I thought that is what you meant, but, I want to eliminate the user clicking that and all layers opening automatically, but I can live with this for now.
Well that is what the other thread will do, based on the code changes (expand all layers automatically).
Have i forgotten a colon again? rscheitlin
