Layer List: Expand Layers by Default
33242
60
06-18-2015 04:26 PM
AdamAraza1
I thought I had posted this on here already, but I can't seem to find it....
I'm using the tab theme and I have the layer list opening by default in the side panel. Is there a way to have it open with all the layers already expanded showing the symbology without having to click on each individual layer?
RobertScheitlin__GISP
George,
   What error is presented in your browsers web console?
GeorgeKatsambas
layer list console
Yep you have introduced a syntax error in your code then.
GeorgeKatsambas
OMG, again!! I  found it, geez , thanks Robert, I looked and looked and did not see it at first.
by Anonymous User
Not applicable
Did WAB 2.5 break this?
I can't get it to work. Anyone else? I tested it here with a completely fresh WAB 2.5.  All I did was add in this code block to enable all popups.They do not work. This was very useful. Esri should add as a config option behavior Kelly Gerrow
Test Site - All Popups Enabled with Mod - WAB 25
GeorgeKatsambas
No it works
Kevin,
   That is not the same topic that is being covered by this thread. You may want to start a new thread.
by Anonymous User
Not applicable
Hi Robert, indeed you are correct! I migrated my widgets but not the WAB base. I recalled your mod was to LayerInfoForDefaultService and LayerInfoForDefault in jimu.js. Thanks! It still works perfect.
KateřinaUhlířová
is it same in 2.14?
Katka
HenryMoore
Yes. Works in 2.15 as well.
