Is it possible to make apps that have an offline editor mode using the Esri Web AppBuilder?
5910
11-04-2015 11:34 AM
BenjaminHarloe
If so can anyone point me to resources on the topic?
DerekLaw
Esri Esteemed Contributor
Hi Ben,
Web AppBuilder does NOT support disconnected/offline editing workflows.
Hope this helps,
DerekLaw
Hi Ben,
Hope this helps,
BenjaminHarloe
The JavaScipt API does though, right? So in theory could you download a web appbuilder app, and then edit it with the JavaScript API to create offline editing functionality?
DerekLaw
Hi Benjamin,
As far as I know, it does NOT support disconnected editing workflows. See the ArcGIS API for JavaScript documentation,
Editing | Guide | ArcGIS API for JavaScript
No. Another requirement for disconnected editing workflows is for the client app to be able to store a local copy of the data that you would be editing offline, as well as sync that data back to the original source data (via a feature service). Web AppBuilder does NOT support this type of capability.
Hope this helps,
PatrickMcKinney1
I was trying to figure out the same thing, and came across ESRI's Offline-editor-js project on GitHub.  It looks like this may be a possible solution, provided you have some knowledgeable developers on your team.
