Increasing selection tolerance in AGOL?
864
10-28-2020 02:06 PM
PRuss
Will this solution listed here for increased click tolerance work in Web App Builder (ArcGIS Online)? Or perhaps a newer solution exists?
We have valid feedback for a viewer here: "I am having a little trouble finding the right place to click to get the info box to pop up on some projects.  Can you add a selection feature to make that easier?"
Please see attached syntax error I am seeing when attempting to use the suggested code in AGOL's (within WAB) Configure Popups (does a JS to Arcade converter exist?) and the code copy / paste below.
In 3.x, you can do this by overriding the "_calculateClickTolerance" function of the map's popupManager property. For example:
map.popupManager._calculateClickTolerance = function(graphicsLayers) {
    return 10;
That is a very simplistic example, but you could implement whatever logic you want inside that function as long as you return an integer (preferably non-negative).
I've read through Your Arcade Questions Answered but have not found a solution yet.
p.s.
In ArcGIS Desktop
under Selection -> Selection Options -> Selection tolerance
exists and wondering where the similar option is in AGOL (WAB) for configure popups.
