Identify Links/Identify Widget
6737
21
02-09-2016 11:10 AM
JasonStanton__GISP
I can't figure out what I am doing wrong.  I want to include an Identify Link (WAB v1.3).  The Link Content is a field and works fine in the Flex version I am transitioning away from.  PopUp Link Type is Text and I have included a Link Alias.  When I try to perform the Identify it comes up with "No Results Found".  If i change the Link Content to a URL it works as expected.  If I delete the Identify Link it will identify features properly.
Looking at it in the Inspector/Console - this is the message, but I don't know what this is 'telling me'.  Any thoughts would be greatly appreciated!
Jason
TypeError: Cannot read property 'type' of undefined(…) "TypeError: Cannot read property 'type' of undefined
    at declare._substitute (https://mrmapper.mrpc.org/webapps/HighCrashLocations/widgets/Identify/Widget.js:1434:22)
    at null.<anonymous> (https://mrmapper.mrpc.org/webapps/HighCrashLocations/widgets/Identify/Widget.js:1088:31)
    at https://js.arcgis.com/3.15/init.js:167:296
    at Object.g.filter (https://js.arcgis.com/3.15/init.js:220:229)
    at declare.showIdentifyResults (https://mrmapper.mrpc.org/webapps/HighCrashLocations/widgets/Identify/Widget.js:923:25)
    at null.<anonymous> (https://mrmapper.mrpc.org/webapps/HighCrashLocations/widgets/Identify/Widget.js:702:16)
    at k (https://js.arcgis.com/3.15/init.js:189:431)
    at q (https://js.arcgis.com/3.15/init.js:189:357)
    at resolve (https://js.arcgis.com/3.15/init.js:191:441)
    rejected at a (https://js.arcgis.com/3.15/init.js:190:337)
    at k (https://js.arcgis.com/3.15/init.js:190:89)
    at https://js.arcgis.com/3.15/init.js:819:56
    at c (https://js.arcgis.com/3.15/init.js:66:221)
    at d (https://js.arcgis.com/3.15/init.js:66:10)
Error
    at then.b.then (https://js.arcgis.com/3.15/init.js:192:253)
    at declare.identifyFeatures (https://mrmapper.mrpc.org/webapps/HighCrashLocations/widgets/Identify/Widget.js:698:19)
    at declare._onDrawEnd (https://mrmapper.mrpc.org/webapps/HighCrashLocations/widgets/Identify/Widget.js:544:14)
    at null.<anonymous> (https://js.arcgis.com/3.15/init.js:167:296)
    at g.(anonymous function).h [as onDrawEnd] (https://js.arcgis.com/3.15/init.js:234:134)
    at declare._onDrawEnd (https://mrmapper.mrpc.org/webapps/HighCrashLocations/jimu.js/dijit/DrawBox.js:389:12)
    at null.<anonymous> (https://js.arcgis.com/3.15/init.js:1204:63)
    at H._drawEnd (https://js.arcgis.com/3.15/esri/toolbars/draw.js:18:262)"
JasonStanton__GISP
My apologies, sometimes by brain gets in the way of itself..  I 'misspoke' I meant to say the service, within the WebMap, end at MapServer, without the /0.
And if it matters I am using Portal not AGOL.
RobertScheitlin__GISP
Jason,
   Portal adds a level of complexity... As I can not test your exact environment. I added your layer and looked at your config_Identify.json and matched it exactly on my end and I am successfully identifying your data.
So I am wondering if some of the other issues that appear in the browsers web console are affecting this.
JasonStanton__GISP
I am at a loss.  If it's not the widget or the data it's probably Portal bc I have had some 'issues' with it.  Thanks for the help!
Jason,
   My debugging plan of attack would be to start by creating a web map that only has the High Crash Locations layer and build a new app with that new webmap and test the Identify widget again.
JasonStanton__GISP
Still didn't work.  Any other thoughts?
That is crazy that you are failing to get identify results and I am able to using your data. What version of the Identify widget are you using? You can hold the alt key on your keyboard and click in the widget to get a dialog that tells you the widget version (I always seem to assume people are using the latest version).
JasonStanton__GISP
I am using the current version - 1.3
I would update 1.3.0.1 then and test again as that is what I am using on my end without issue.
JasonStanton__GISP
ok, thanks!
JasonStanton__GISP
Unfortunately that did not work either.
