Hyperlink to Shapefile in Map from Teams
1574
03-29-2021 11:53 AM
Kelin_Field
I have a map built on ArcGIS Online.  The map contains easements in varying stages of completion.  The data is stored in an Excel database on Microsoft Teams.  We update the map manually with the same data stored as an attribute table in the easement shapefiles.  In order to assist the team, I am attempting to add a hyperlink field in the Excel file that will link the easement agreement number to its matching shapefile in the ArcGIS Online Map.
Desired Function:  A user clicks a hyperlink in the Teams file that says "View on Map".  This opens a web browser which directs to the ArcGIS Online map and Queries the map using the data from that particular Excel "Easement ID" column to search for a shapefile with the matching data in the same column of the attribute table and zooms the view to that easement.
I have tried using the "Query" widget but it will not load any layers from the map nor layers I have uploaded to my content and I cannot move past that first step.
Any help is appreciated.
DavidPike
MVP Notable Contributor
I don't use AGOL unfortunately but I'd guess you have the share widget available - Share widget—ArcGIS Web AppBuilder | Documentation
I would probably look at the URL string formed from a test query with your desired parameters then play about with creating URLs based on each feature/row in your spreadsheet.
DavidPike
Kelin_Field
Thank you David.  I believe this is going to give me my basic functionality.  I can do a current extents share but for some reason my query function to locate a specific feature is not loading any of my layers.  Its acting like I have a blank map.  Once I figure that out I should be able to share a hyperlink by specific feature attributes within the URL.
