How to remove measures in the Measurement widget ?
1823
04-09-2018 12:44 AM
LioritClément
I would like to remove measures that I do not use in the Measurement widget.
RobertScheitlin__GISP
Liorit,
   In the Widget.js you can add this code:
Line 17 I am setting the default length unit to Kilometers.
Line 28 and 29 I am removing Miles as an option.
      startup: function() {
        if (this.measurement || this._pcDef) {
          return;
        this.inherited(arguments);
        var json = this.config.measurement;
        json.map = this.map;
        if (json.lineSymbol) {
          json.lineSymbol = jsonUtils.fromJson(json.lineSymbol);
        if (json.pointSymbol) {
          json.pointSymbol = jsonUtils.fromJson(json.pointSymbol);
        this._processConfig(json).then(lang.hitch(this, function(measurementJson) {
          measurementJson.defaultLengthUnit = esriUnits.KILOMETERS;
          this.measurement = new Measurement(measurementJson, this.measurementDiv);
          this.own(aspect.after(this.measurement, 'setTool', lang.hitch(this, function() {
            if (this.measurement.activeTool) {
              this.disableWebMapPopup();
            } else {
              this.enableWebMapPopup();
          this.measurement.startup();
          this.measurement._distanceUnitStrings = ["Kilometers", "Meters"];
          this.measurement._distanceUnitStringsLong = ["esriKilometers", "esriMeters"];
          this._hideToolsByConfig();
        }), lang.hitch(this, function(err) {
          new Message({
            message: err.message || err
Liorit,
          return;
            } else {
          new Message({
GuillaumeDENIAUD
I would answer for Clément whose traineeship is over :
"Thank you Robert, that was exactly what I was looking for"
I can't close directly this ticket for him but we can consider it as close.
Thanks
