I have succeeded in hiding the set location hover icon on the map ( ) but then the set location icon appears on NearMe widget tool bar which users can click
. How can I comment out the code to hide/remove the set location icon from the map so that users cannot find it.
Thanks Simon.
Simon,
In the Widget.js file comment out the contents of the _connectMapEventHandler function.
_connectMapEventHandler: function () {
// if (!this._mapClickHandler) {
// this._disableWebMapPopup();
// //handle map click
// this._mapClickHandler = this.own(this.map.on("click", lang.hitch(this,
// this._onMapClick)))[0];
// //handle mouse move on map to show tooltip only on non-touch devices
// if ("ontouchstart" in document.documentElement) {
// domStyle.set(this._mapTooltip, "display", "none");
// } else {
// this._mapMoveHandler = this.own(this.map.on("mouse-move", lang.hitch(
// this, this._onMapMouseMove)))[0];
// this.own(this.map.on("mouse-out", lang.hitch(this, function () {
Simon,
Just un-check the "Set location button" in the widgets settings > search settings tab.
Hello Robert, thanks for the prompt reply. I had tried this before, it worked but then presented a new challenge/issue. When the ‘set location button’ is turned off, you don’t see this icon on the NearMe widget which is what I need but users are able to hover over map using the ‘set location’[cid:image003.png@01D55429.E5615050] . To summarize it all, by default, the set location button is turn off, users can hover over map and use the set location ( I do not want users to be able set location on the map). When the ‘set location’ is turned on, users cannot hover over the map and set location (what I want), but then the set location icon appears on the NearMe widget which then allow users to click and set location (I do not want this either).
Simon.
Simon,
// } else {
Thanks Robert, It worked as expected.
