How to attach listener to WAB geoprocessing widget drop down
1002
10-28-2019 09:00 AM
MichaelMitchell5
I'm modifying geoprocessing Widget.js to create cascading drop down menus.  I'm attempting to attach a listener to one of the menus.  I'm doing this towards the bottom of the _createInputNode method.
if(param.name == "Habitat_type"){
        console.log("attach listener");
        on(inputEditor, "change", lang.hitch(this, this.selectChange));
"attach listener" shows in the console but when I change the drop down selection the selectChange method doesn't run.
Thanks for the help!
MichaelMitchell5
I changed inputEditor to inputEditor.gEditor and it worked.  I found this by looking at editorManager.js and found the spot where editorName === 'Select' then saw o.gEditor.  After debugging the trouble line in the code I saw that the inputEditor object had a gEditor parameter.  Forgive the terminology if it's wrong.
MichaelMitchell5
