How do I create a website link?
4898
04-14-2015 10:00 AM
ThaoLe1
When I click on the created ESRI link, it will open another webpage.  How can I configure it so that it opens in the same webpage?
RobertScheitlin__GISP
Thao,
  There is no json configuration for the target setup in the source code. If you want to do something like that then you will have to modify the source code for the HeaderController/widget.js.
Find the file here "themes\FoldableTheme\widgets\HeaderController\Widget.js" and then find the _createDynamicLinks function there @ line 376 you will find the target hard coded to '_blank'
Thao,
ThaoLe1
Thanks Robert, it works perfectly.
StanMcShinsky
Thao,
but change it to
target: link.target,
Then go into your config at the root of your application and add the comma and a target option.
"links": [
      "label": "test",
      "url": "http://www.esri.com",
      "target": "_self"
This allows you to now change it in the config file.
-Stan
ThaoLe1
Stan, I tried your suggestion and it worked as well. Thanks.
