How do I change the results label for the measurement dijit
3685
5
01-15-2016 06:21 AM
AnthonyGiles
Honored Contributor
All,
Is it possible to change the default value for the measurement dijit from 'Measurement Result' to some other text in a single widget:
I tried changing the following localisation value within the widget:
esriBundle.widgets.measurement.NLS_resultLabel = "new value";
Which worked but it changed the values for all measurement result labels and I only want to change it in the one widget.
Regards
Anthony
RobertScheitlin__GISP
Anthony,
  In that case then direct dom manipulation is best:
Add 'dojo/query' require to the widget.js and then make these changes to the startup function (lines 20 - 23):
      startup: function() {
        if (this.measurement || this._pcDef) {
          return;
        this.inherited(arguments);
        var json = this.config.measurement;
        json.map = this.map;
        if (json.lineSymbol) {
          json.lineSymbol = jsonUtils.fromJson(json.lineSymbol);
        if (json.pointSymbol) {
          json.pointSymbol = jsonUtils.fromJson(json.pointSymbol);
        this._processConfig(json).then(lang.hitch(this, function(measurementJson) {
          this.measurement = new Measurement(measurementJson, this.measurementDiv);
          this.own(aspect.after(this.measurement, 'setTool', lang.hitch(this, function() {
            if (this.measurement.activeTool) {
              var measLbl = query(".esriMeasurementResultLabel", this.domNode)[0];
              if(measLbl){
                measLbl.innerHTML = measLbl.innerText = "My Measurement Result";
              this.disableWebMapPopup();
            } else {
              this.enableWebMapPopup();
          this.measurement.startup();
        }), lang.hitch(this, function(err) {
          new Message({
            message: err.message || err
Anthony,
   I would suggest doing the esriBundle.widgets.measurement.NLS_resultLabel = "new value"; in the onOpen function of the widget than reset it onClose (which means you need to save the original in a var). Esri does this in their Edit widget
AnthonyGiles
Honored Contributor
Cheers Robert,
That sort of works but doesn't seem to be an elegant solution in my opinion.
If you open a second widget that contains the measurement dijit before you close the first the label will be incorrect. Which means you need to add the code into the open and close of each potential widget.
Never mind if that,s the only work around
Reagrds
Anthony
Anthony,
          return;
              if(measLbl){
            } else {
          new Message({
AnthonyGiles
Honored Contributor
Cheers Robert,
I've finished for the weekend I will have a look Monday and let you know how I get on.
thanks again
Anthony
AnthonyGiles
Honored Contributor
Spot on Robert,
Thanks Again
