How can we add minimize/maximize button to OnScreen widget while viewing in Tab/iPad also
1591
05-11-2019 07:02 AM
Vara_PrasadM_S
Hi Team,
For On Screen widgets in ESRI Web AppBuilder, minimize/maximize buttons are visible only in mobiles but not in iPad / Tabs. Could someone please tell me how can we add.
Robert Scheitlin, GISP‌, Could you please give me some ideas how can we do this. Thanks in advance!
Thanks & Regards,
Vara Prasad
RobertScheitlin__GISP
Vara,
    The apps mobile break point is set to a width of 600 in the main.js that is what determines if the app goes into mobile mode or not and because most iPads and tablet have a screen width of greater than 600 it will not show the buttons. To fix this in the main.js change this:
    jimuConfig = lang.mixin({
      loadingId: 'main-loading',
      loadingImageId: 'app-loading',
      loadingGifId: 'loading-gif',
      layoutId: 'jimu-layout-manager',
      mapId: 'map',
      mainPageId: 'main-page',
      timeout: 5000,
      breakPoints: [600, 1280]
    }, jimuConfig);
Line 9 change the 600 to less.
Vara,
      mapId: 'map',
      timeout: 5000,
    }, jimuConfig);
Vara_PrasadM_S
Thanks a lot Robert Scheitlin, GISP‌. It worked.
With Regards,
Vara
