Hot Swap maps in WAB?
1397
08-09-2018 05:50 AM
HunterCarver
I'm trying to have my WAB setup so that I can change out the underlying maps without doing a lot of changes to WAB widgets.  Essentially I want to reuse the same WAB application with different maps so that the look and functionality are consistent across all the maps.  I built a "Widget" map layer that I add to all the maps to be used by attribute table, etc.  and I set up chart widget with connections to Portal layers instead of map.  However when I try swapping in a new map, the settings are all still there in the chart widget and Search widget but I still have to manually reset the setting to get it to work.  I'm trying to roll out an upgrade to our map series and it would save a lot of time if I could get this to work.
ArcServer w federated Portal 10.3.1, WAB 2.6
Thank You,
RobertScheitlin__GISP
Hunter,
   There is this custom widget.
https://community.esri.com/docs/DOC-7630
MichaelDeliberato
Im having a little trouble Configuring this widget. it doesn't seem to populate my content and just tells me what user i am logged into. any help would be greatly appreciated
You should ask for help with that widget on that widgets page I provided above.
