Hitting the "Enter" key produces the wrong results...
1021
03-02-2023 02:38 PM
sr_guy
I created this map based on the ERST map, so my dept can quickly find servicing power companies based on address. I am using the "Nearby" ArcGIS app. Here is my application.
Everything is working fine, except one problem. If I paste an address, for example:
4300 E Central Texas Expy, Killeen, TX 76543
And hit enter on my keyboard automatically without selecting a dropdown result first, it returns results in Kansas instead of the correct state. If I use down arrow on my keyboard, or click on the result manully, results work fine. It was just recently that this issue started when hitting "Enter" first. Is there a setting in the Nearby app that would cause this?
sr_guy
I figured out how to resolve this issue. I corrected this section, and the "arcgis world geocoding service" settings.
Omar_A
by Esri Contributor
Try to check the app settings and see if there is an option to adjust the default search behaviour. Specifically, you may want to look for options related to search prioritization, location preferences, or search radius. Depending on the app version and settings, you can adjust these settings to prioritize results closer to the address you entered or to give more weight to specific search criteria.
sr_guy
