Group Filter URL Parameters
1686
05-31-2023 05:05 AM
MarcoConopio2
I am trying to activate the group filter in my webapp via URL parameters.I have this Group Filter.
Hence my url is like this
https://<your portal URL>/apps/webappviewer/index.html?id=<Item ID>&groupfilter={“Year”:[“2023”]}
However it doesnt seem to work and my webapp is not loading at all
Any idea why is it not working?
AlixVezina
@MarcoConopio2  Just verified this on my end in the ArcGIS Online edition of Web AppBuilder and it seems to be working as expected, here's an example URL parameter.
At first glance, I'd say make sure the quotes are " and not  ?
If that doesn't resolve the issue, are you using ArcGIS Online or Enterprise Portal, or perhaps the developer edition? Any special security setup on your server?
StuMcKay
@MarcoConopio2 did you ever get to the bottom of the issue you were experiencing? I'm getting the exact same error.  The filter works fine in the web app but when i try and control it through a URL i get the same error you were experiencing.
LauraAnderson1
@MarcoConopio2 @StuMcKay Have either of you figured this out? I am experiencing the same thing now
