Group Configuration for WAB DE
3778
8
05-21-2019 05:27 PM
JamesKo
I've setup some group widgets in my WAB DE 2.12 app config file. Although the functionality works, I'm receiving an error in the console. This only happens when I configure the "groupSetting" in the header controller config to use type: "dropdown". Is this a bug?
js.arcgis.com/3.28/init.js:115 TypeError: Cannot read property 'className' of null at Object.add [as addClass] (js.arcgis.com/3.28/init.js:216) at Object. (themes/FoldableTheme/widgets/HeaderController/Widget.js?wab_dv=2.12:1136) at js.arcgis.com/3.28/init.js:64 at l (js.arcgis.com/3.28/init.js:108) at e.then.b.then (js.arcgis.com/3.28/init.js:111) at Object._showIconContent (themes/FoldableTheme/widgets/HeaderController/Widget.js?wab_dv=2.12:1133) at Object. (themes/FoldableTheme/widgets/HeaderController/Widget.js?wab_dv=2.12:1023) at js.arcgis.com/3.28/init.js:64 at l (js.arcgis.com/3.28/init.js:108) at k (js.arcgis.com/3.28/init.js:108) "TypeError: Cannot read property 'className' of null at Object.add [as addClass] (https://js.arcgis.com/3.28/init.js:216:220)
RobertScheitlin__GISP
James,
   Make these edits to the HeaderController Widget.js (line 31-33, 38-40, 45-47):
      _showIconContent: function(iconConfig) {
        var iconNode;
        if(iconConfig.inPanel === false){
          this.widgetManager.loadWidget(iconConfig).then(lang.hitch(this, function(widget) {
            this.openedId = iconConfig.id;
            iconNode = this._getIconNodeById(iconConfig.id);
            query('.icon-node', this.domNode).removeClass('jimu-state-selected');
            html.addClass(iconNode, 'jimu-state-selected');
            //we don't call widget.startup because getWidgetMarginBox has started widget
            //widget.startup();
            html.setStyle(widget.domNode, 'zIndex', 101);
            this._setOffPanelWidgetPosition(iconNode, widget);
            this.widgetManager.openWidget(widget);
            // ST: Added to listen for out of panel widgets that can be closed
            this.own(aspect.after(widget, 'onClose', lang.hitch(this, function() {
              this._unSelectIcon(iconConfig.id);
              // console.log(widget);
              // if (this.openedId && this.openedId === iconNode.config.id) {
              this._switchNodeToClose(iconNode.config.id);
              iconNode.focus();
        }else{
          this.panelManager.showPanel(iconConfig).then(lang.hitch(this, function(panel) {
            if(iconNode){
            this.own(aspect.after(panel, 'onClose', lang.hitch(this, function() {
              if(iconNode){
                iconNode.focus();
            this.own(on(panel.closeNode, 'keydown', lang.hitch(this, function(evt){
              if(evt.keyCode === keys.ESCAPE){
                if(iconNode){
                  iconNode.focus();
James,
   Not sure if it is just a typo in your post but the proper value is dropDown.
JamesKo
Hi Robert,
Yes, it was just a typo in the post...
I also created a new clean site in Web AppBuilder for ArcGIS and used the Foldable theme and got the same console error. It doesn't seem to affect functionality.
Can you share you config.json for review?
JamesKo
I've attached the groups tag...
James,
        var iconNode;
            //widget.startup();
              iconNode.focus();
        }else{
            if(iconNode){
              if(iconNode){
                iconNode.focus();
                if(iconNode){
                  iconNode.focus();
JamesKo
Bingo, thanks Robert!
Autoridad_Nacional_del_AguaANA
Hi. This problem also occurs in Launchpad. When to minimize the widget and want to drag. It gives a "className of null" error.
This is something that will have to be reported to esri tech support.
