I've created a custom widget in web appbuilder developer edition. I can add it to an app within web appbuilder without issue but when I try to launch the app I get an "i18nLabels is undefined" error.
Has anyone encountered this?
What does your nls/strings.js file look like?
This is what I've got:
Try removing the parenthesis from "root". The documentation strings file looks like this
define({ root:{ label1: "I am a demo widget.", label2: "This is configurable." }, "zh-cn": true });
I don't have any other languages in my app so far, so mine just looks like this.
define({ root: { allSelections: "All selections", appliedChanges: "Successfully applied changes", appliedFailed: "Applied failed!", //etc } // add supported locales below: // , "zh-cn": true });
. You don't need to add all the language options until you have created their appropriate strings files.
Still getting the error. I only added all the language options because I was getting the error and thought I needed them.
As for the parenthesis in root. I removed it but it did not change anything. Funny thing is that I got that file from the CustomWidgetTemplate in samplewidgets. They all seem to have those parenthesis but as you note the doc says otherwise.
Is your file structure like what's shown on this page?
How are you using the nls variables in you Widget.html or Widget.js files?
Here are the examples from my widget:
Widget.html
<div data-dojo-attach-point="btnSignIn" id="signinbtn" class="jimu-btn apply" data-dojo-attach-event="onclick:signIn"> ${nls.signin} </div>
Widget.js
resultMessage = this.nls.allSelections;
I have no variables in my nls/strings.js. Just the _widgetLabel and two _featureAction_.
I'm really not sure what is going on. Thanks for your help though.
I mean how are you using _widgetLabel and the others in your app?
I'm not. _widgetLabel is just the name of the widget as it appears in web appbuilder and the _featureAction_ labels is what shows up when you click a feature. They are not strings used in the app.
So where are you getting the error about "i18nLabels"?
I'm getting the error when I launch the app from web appbuilder. I get the error in the browser's developer console.
Although, I think I may have figured something out. In the widget's manifest.json I had set the property hasLocale : false. I need to do more testing but this may be causing the error. I removed the property and I did not receive the error. I'll update this post when I know for sure.
Signed in members can post, follow updates, and more. New here? Register a free account.
