Filter by date - does not show Saturday??
1483
06-13-2023 12:59 PM
KarenEllett
I've realized that users cannot select any date on Saturday.  If we set up a default date in the widget, we can see Saturdays:
However, we have it set to ask the user for values for the date.  When they select a date, they see this:
This is a pretty significant issue for us, as our users need to be able to select the last day of the month to get accurate results.  Is there something here I'm missing?
ChrisUnderwood
Hello @KarenEllett ,  Is your app created from a particular Web AppBuilder Theme ?
There is a Bug, ref BUG-000123554, that describes this problem with the Launchpad theme. The Bug is fixed in ArcGIS Enterprise version 10.9.1.
https://downloads.esri.com/support/downloads/other_/1091-IssuesAddressedList_111921.pdf
Hope this helps.
ChrisUnderwood
Hope this helps.
KarenEllett
Thank you so much, this was in fact exactly the issue.
